DIAdem
Sort Functions
Is there a function to sort an array of Strings or an array of numbers within DIAdem?
Some of the particulars are I would like to extract a column of data that is returned from an advanced query in the datafinder, then sort that list.
I can't seem to find a function that sorts arrays in DIAdem.  Maybe I don't know the german word for it! (HA)
Jim West
Summitek Instruments
(4,353 Views)
Hi Jim
In DIAdem you have the command ChnMultipleSort to sort DIAdem channels. To sort a field you find a lot of scripts in the internet e.g. the bubblesort algorithms. The following script sorts an array. It works good, if the array is not to big.
Function bubblesort(arrSort)
Dim iTemp, j, arrTemp
  For iTemp = 0 to ubound(arrSort)
    For j = iTemp + 1 to ubound(arrSort)
      If UCase(arrSort(iTemp)) > UCase(arrSort(j)) Then
        arrTemp = arrSort(iTemp)
        arrSort(iTemp) = arrSort(j)
        arrSort(j) = arrTemp
      End If
    Next
  Next
  bubblesort = arrSort
End Function
Hope this helps
Winfried
(4,337 Views)
Thank you for the code.  I guess I could written that...
Since I usually develop in LabVIEW, I have become lazy.  I just assume that all 'sorts' of functions are builtin.
jim
(4,326 Views)
