DIAdem
Property Information When Using DataFileLoad and DataFileLoadSel
Hi
When I load data using the DataFileLoad command DIAdem creates a new group with the file name and I have access all of the custom data properties.  However when I use the DataFileLoadSel command I specify which channels I want loaded but the new data group does not retain any of the custom data file properties.
Is this behavior expected?  If so is there away for me to load custom data file properties when using the DataFileLoadSel command?
Tim
(3,845 Views)
Hi smoothdurban.
Yes, this is expected. The default is that DIAdem just loads the properties for the object (and below) you selected (Root or Group or Channel). But you can specify whether the properties from higher levels should also be loaded.
Greetings
Walter
(3,811 Views)
Accepted by smoothdurban
You can use some kind of auto class to get a loadingbehavior that is not dependent on the settings.
call Load()
Sub Load()
  dim AutoLoadMode : set AutoLoadMode = new CAutoLoadMode
  call DataFileLoadSel("example.tdm",,"[1]/[2,3]")
end sub
class CAutoLoadMode
  Private Sub Class_Initialize()
    ' save old values
    PropInheritanceModeDF_     = PropInheritanceModeDF
    PropInheritanceMode_       = PropInheritanceMode
    PropNamingSchema_          = PropNamingSchema
    BulkDataLoadingMode_       = BulkDataLoadingMode
    ChnCharacteristicsUpdate_  = ChnCharacteristicsUpdate
    ' set your defaults
    PropInheritanceModeDF = "MoveToLoadedLevel"
    PropInheritanceMode = "MoveToLoadedLevel"
    PropNamingSchema = "TypeNamePropertyName"
    BulkDataLoadingMode = eBulkDataLoadingImmediately
    ChnCharacteristicsUpdate = "Automatic"
  End Sub
  Private Sub Class_Terminate()
    ' set back old values
    PropInheritanceModeDF    = PropInheritanceModeDF_
    PropInheritanceMode      = PropInheritanceMode_
    PropNamingSchema         = PropNamingSchema_
    BulkDataLoadingMode      = BulkDataLoadingMode_
    ChnCharacteristicsUpdate = ChnCharacteristicsUpdate_
  End Sub
  private PropInheritanceModeDF_
  private PropInheritanceMode_
  private PropNamingSchema_
  private BulkDataLoadingMode_
  private ChnCharacteristicsUpdate_
end class
The available parameters can always be retrieved using CTRL+Shift+C in the settings dialog which will put them into clipboard.
(3,807 Views)
This will do the trick.
Tim
(3,787 Views)
