DIAdem
PicFileAppend issue
When I open up Diadem fresh and run this command it doesnt do anything. Meaning I dont see the report tab that was imported in the REPORT view. If I run the same script again then it shows. I tried the Call PicUpdate command after it too. That doesnt do anything either.
Call PicFileAppend("path\fileName.TDR")
(4,159 Views)
Hi Anne,
What version of DIAdem are you using? I tried to replicate the problem by running the following script but everything works fine.
Option Explicit  'Forces the explicit declaration of all the variables in a script.
Call PicFileAppend("C:\Users\Public\Documents\National Instruments\DIAdem 2010\Documents\Example.TDR")
Call PicUpdate
Let me know if this works for you.
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
(4,135 Views)
Hi Sean
I am using Diadem 11.1
It happens only the first time the script is run after Diadem is launched. After that it works fine.
I've tried different TDR files as well.
Anne
(4,117 Views)
Accepted by anne
Hi Anne,
If the REPORT panel has never been opened, then you need to programmatically open the REPORT panel before calling any REPORT functions-- try inserting this command at the top of your script:
Call WndShow("REPORT")
Brad Turpin
DIAdem Product Support Engineer
(4,110 Views)
Thanks Brad. That works.
-Anne
(4,100 Views)
