 DaSebse
			DaSebse
			11-07-2008 07:42 AM
Hi there,
can s.o. explain me the meaning of the parameter "OrdAFFiltRecalc" for the function "ChnOrdAFCalc", please?
Thanks a lot!
11-10-2008 09:25 AM
you find all in the Diadem help when searching to these commands
or looking in that links for additional issues ("Order Analyses")
http://forums.ni.com/ni/board/message?board.id=60&message.id=8298&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=60&message.id=6481&requireLogin=False
Best Regards
Johann
11-10-2008 11:23 AM
I read the DIAdem help and the threads. And I understand most of the parameters for the Order Analysis, but what does this special parameter affect?
In the help they mention "filter coefficients that are recalculated", but what filter coefficients must be recalculated during an order analysis?
Why should this parameter have another value than OrdRevolStep, because it doesn't make sense to calculate sth. at other points than the ones specified by OrdRevolStep?
11-11-2008 03:07 AM
it makes sense that the when look in http://de.wikipedia.org/wiki/Ordnungsanalyse
you see the "fixed rotation speed" for calculating analyses - therefore it´s necessary to actualize the coeffizients when speed changes and (fixed speed is very short -> coeffizient must calculate very often).
The resolution of analyses is calculating with OrdRevStep and you are right that this can be the same but you can also say you want do actualizise later the coeffizients than you need a second parameter for these settings. Therefore the 2 parameters instead of only OrdRevStep...
Best Regards
