DIAdem
Maximize DIAdem application window.
How to make my DIAdem application window set to maximum size [ fit to window] using script?
For example: see below image. How to fit my diadem application to window size using script?
I want to run my script in maximized window and sometime if user didn't keep it in maximized size, I want to include maximize window lines in the start of the script to handle this use case.
something like,
    Application.WindowState = xlMaximized
    windWidth = Application.width
    windHeight = Application.height
regards,
Durai
(1,871 Views)
Accepted by topic author Durai26
Hi Durai,
you can use WndShow() for this.
To maximize the window use :
call WndShow("SHELL","MAXIMIZE")
To switch back to windowed mode use :
call WndShow("SHELL","NORMAL")
(1,834 Views)
