DIAdem
How to know what version of DIAdem is being called by LabVIEW
I wasn't sure if I should ask this in the DIAdem forum or LabVIEW forum. I have a LabVIEW script which is opening DIAdem data file, report file, and script. I have DIAdem 2012 and DIAdem 2015 installed on my computer. Is there a way to know which DIAdem is being used when LabVIEW runs this code?
(3,906 Views)
What are you using to call DIAdem in LabVIEW?  There may be a method included in whatever library/palette in LabVIEW that you are using to retrieve the version information from DIAdem.
Highest Regards,
Paul
(3,859 Views)
I'm using `DIAdem Open Reference.vi`
(3,853 Views)
It's always the last opened version. I'm not sure if there is a way to choose what version to use exactly.
Regards
Christian
CLA, CTA, CLED
(3,851 Views)
Accepted by topic author TheStrangeQuark
You could try this function:
Which is documented to output the version and revision of the DIAdem application that is open.
Highest Regards,
Paul
(3,845 Views)
