08-24-2004 02:03 PM
08-24-2004 05:37 PM
08-25-2004 10:28 AM
06-21-2006 02:50 AM
09-18-2008 02:52 AM
hi,
It's very nice to have some information about how to load data from datastore. but i want to know one more thing, suppose we want to load data from datastore to dataportal through scripting then how to write that script?what is storageABS? IS this any key for loading any of the channel from datastore.
09-18-2008 03:06 AM
one more thing is when i was loading the data through datastore(when scripting is enabled) The script written is shown below.
Option Explicit 'Forces the explicit declaration of all the variables in a script.
Call DataDelAll(1) '... HeaderDel
Call StorageImport("<?xml version=""1.0"" encoding=""UTF-16""?><addressgroup version=""1.5""><addresslist><basepoint name=""theStore""><usistore name=""""><type>Citadel5</type><param><cit5><alarms>false</alarms><db>\\nidhi\c__program_files_national_instruments_labview_8_5_data</db><interval enabled=&quot;false&quot;><delta enabled=&quot;false&quot;>5.0</delta><end>20080916092403000000000</end><start>20080916082403000000000</start></interval><quality>false</quality><timeout>30</timeout><trans enabled=&quot;false&quot;><brkratio>false</brkratio><delta>5.0</delta><etm>false</etm><interp>false</interp><max>false</max><mean>false</mean><min>false</min><mode>Natural</mode><qualratio>false</qualratio><starts>false</starts><stddev>false</stddev><stops>false</stops></trans><waveforms relativeTime=&quot;false&quot;>Mixed</waveforms></cit5></param></usistore></basepoint><address><basepointref>theStore</basepointref><abskey>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
59ff0aff0fff1dff45ff42ff4eff4dff48ff47ff4eff53ff17ff14ff08ff4bff40ff45ff50ff57ff53ff45ff72ff7bff73ff68ff70ff7fff60ff26ff2bff62ff6cff64ff76ff2cff75ff71ff7bff6fff31ff23ff7fff73ff79ff6dff39ff3aff2aff67ff6bff63ff6fff6efe9afe92fe96fe99fe82fec4fec5fed7fe9cfe93fe8cfeca</abskey></address></addresslist></addressgroup>","") '... StorageABS,ImportAction
Call StorageImport("<?xml version=""1.0"" encoding=""UTF-16""?><addressgroup version=""1.5""><addresslist><basepoint name=""theStore""><usistore name=""""><type>Citadel5</type><param><cit5><alarms>false</alarms><db>\\nidhi\c__program_files_national_instruments_labview_8_5_data</db><interval enabled=&quot;false&quot;><delta enabled=&quot;false&quot;>5.0</delta><end>20080916092403000000000</end><start>20080916082403000000000</start></interval><quality>false</quality><timeout>30</timeout><trans enabled=&quot;false&quot;><brkratio>false</brkratio><delta>5.0</delta><etm>false</etm><interp>false</interp><max>false</max><mean>false</mean><min>false</min><mode>Natural</mode><qualratio>false</qualratio><starts>false</starts><stddev>false</stddev><stops>false</stops></trans><waveforms relativeTime=&quot;false&quot;>Mixed</waveforms></cit5></param></usistore></basepoint><address><basepointref>theStore</basepointref><abskey>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
1aff41ff41ff5eff0fff0cff00ff5aff5fff4dff48ff4fff42ff4dff5eff18ff19ff0bff4eff47ff40ff53ff6aff6cff78ff71ff7eff74ff6dff73ff72ff6fff2bff28ff3cff79ff74ff69ff31</abskey></address></addresslist></addressgroup>","") '... StorageABS,ImportAction
Now when i tried to run this script it's giving error "string variable is unterminated" so what to do for that?
09-18-2008 11:01 AM
This occurs because the XML string the VBScript recorder records is too long for VBScript to have on one command line. You have to break up that long line into multiple lines with either the "_" operator or with an approach like this:
XML = "lkhsgadfglkasligasfg"
XML = XML & "KJSHGDFKJHDSFKHJ"
See my other post to you today for an alternative and more parametric programmatic load option.
Brad Turpin
DIAdem Product Support Engineer
09-19-2008 01:53 AM
Thanks for all your help, i did according to you,i made seperation b/w the lines according to you, but while running that script DIAdem is loading same data which is there in the data portal,even if we change the values for different data then also it's showing same behaviour.it is loading same data in portal which is loaded just before the script run.
09-19-2008 05:16 AM
Hi ,
I tried according to what you told,i tried to seperate the line by "_" operator, after doing that it's giving error "unable to import all channels in data store" . it's not importing the data into the portal, so what should i do for that? now i am tring to import values of only one variable through citadel database. i am sending attatchment of script. can you please answer me what's the problem?
09-19-2008 08:58 AM
Hi 8,
You raised two issues in this last post. DIAdem loads a data set with 4 groups by default into the Data Portal. You can change this behavior by choosing the following menu: "Settings>>Options>>NAVIGATOR" and removing the default file path in that dialog. You then need to choose the following menu: "Settings>>OPtions>>Save as" in order to save this setting change into your Desktop.DDD file, so that the next time you launch DIAdem it will remember this change.
The other issue you mentioned was that you were unable to load all the data programmatically from the Citadel data base. How many channels were you attempting to load? What happens when you try the same thing with a program that jjust loads one channel from Citadel?
Brad Turpin
