10-06-2009 03:55 AM
is it possible to edit/change the CAN-Input via vbs? Actually i have often changing or new dbc files for measurement and want to support the user with adding and renaming the signals, without changing the diagram manually.
diademi
10-08-2009 06:03 AM
Hello diademi,
I assume you are talking about DIAdem DAC and you mentioned the DBC (CAN-DB) files. If that's true you must address that request to Vektor, the company who developed that device driver.
Greetings
Walter
