DIAdem
How to add CAN Signals via vbs
is it possible to edit/change the CAN-Input via vbs? Actually i have often changing or new dbc files for measurement and want to support the user with adding and renaming the signals, without changing the diagram manually.
diademi
(3,837 Views)
Hello diademi,
I assume you are talking about DIAdem DAC and you mentioned the DBC (CAN-DB) files. If that's true you must address that request to Vektor, the company who developed that device driver.
Greetings
Walter
(3,801 Views)
