DIAdem
How to access to the property CANBusNumber and CANDBName of a channel group
I'm working with Diadem 2015.
I have converted a BLF file into tdm. I have some channel groups that correspond to my multiplexer mode.
I would like to access to the properties CANBusNumber and CANDBName with a script. What is the syntax to access to this properties? A syntax like Data.Root.ChannelGroups(1).Properties("CANBusNumber").Value does not seem to exist ?
Kind regards,
Xavier
(3,129 Views)
Hello Xavier,
just show the property in the DataPortal. Then Drag & Drop the property to a script. When you drop, DIAdem will generate the script snippet required to access the property.
Hope that helps
(3,107 Views)
Hello Andreas,
Yes it works perfect. Thanks for your help.
Xavier
(3,094 Views)
