04-06-2007 01:30 PM
04-08-2007 12:41 AM
| Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
04-08-2007 10:47 PM
Hi mrclary,
No, the DataFinder does not currently support logical OR'd conditions. The best workaround I can suggest is to programmatically run the query twice, once with value A, once with value B (where A and B are the two or more OR values in the condition). You can programmatically load the search results from each query into the Data Portal and merge them there. This is not pretty, but it will work if you absolutely have to have ORs.
Let me know if you want more info on this,
Brad Turpin
DIAdem Product Support Engineer
04-09-2007 07:46 AM
04-10-2007 10:18 AM
Hi mrclary,
Rest assured that OR operators in the NAVIGATOR and for the DataFinder have been frequently requested as a new DIAdem feature. This is not coming in the DIAdem 10.2 release this Spring, by I am hopeful for the future-- R&D knows that this is important for our users.
For your query merging, let me ask you if you are wanting to load rows (if so Files, Groups, or Channels), or if you are wanting to load property columns. In the former case I would guess that each row would be loaded into one or more new channels with no channel appending necessary. In the latter case I would guess that you would want each separate set of query results merged into the same set of data channels using channel appending.
Let me know your particular merge situation,
Brad Turpin
04-10-2007 10:36 AM
04-10-2007 06:15 PM
Hi mrclary,
OK, for row loading here is an example you ought to be able to use without needing to edit it. You can call your own custom script after the queries are automated and merged in case you want to perform actions afterwards, and you can programmatically create the Parameter Query files prior to calling the "Merge Queries.VBS" script with ScriptStart() if you want to run stuff beforehand.
Notice that all the various OR values for each property are in a single "Param # Description.TDQ" file, so that you can easily create these interactively or programmatically. You can have up to 20 separate OR parameters, plus as many extra AND conditions as you want (in the "Main Query.TDQ" file.
Ask if you have questions,
Brad Turpin
05-29-2007 07:41 AM
