DIAdem
Find maximum Y value of all curves in a 2DAxis chart
Is there a way to get maximum Y value of all the Y values in a chart?
The number of curves, Y channel and Y channel expression will be changing with respect to report template used. Need to refer the channels and expression used in report template to find maximum Y value among all the curves in the chart.
Is there any DIAdem script command to do it in a better way?
Example:
In this template, 5 curves with 3-Y channels and 2 -Y expression channels. How to find the maximum value of Y among these 5 curves using DIAdem scripts?
Durai
(3,230 Views)
Call LogFileDel
Call GetMaxOfAllViewSheetCurves()
Function GetMaxOfAllViewSheetCurves()
  Dim oSheet, oArea, oCurve, oChnX, oChnY
  Set oSheet = View.ActiveSheet
  Set oArea = oSheet.ActiveArea
  For Each oArea In oSheet.Areas
    If oArea.DisplayObjType = "CurveChart2D"Then
      For Each oCurve In oArea.DisplayObj.Curves2D
        Set oChnY = Data.GetChannel(oCurve.YChannelName)
        Call ChnCharacter(oChnY)
        Call LogFileWrite("Curve # " & oCurve.Index & vbTab & oChnY.GetReference(eReferenceIndexName) & vbTab & " max: "  & Str(oChnY.Maximum,"AutoAdj") & " " & oChnY.UnitSymbol)
      Next
    End If
  Next
End Function  'GetMaxOfAllViewSheetCurvesIO
(3,199 Views)
Hi Mark,
will the code work with report sheet?
I am trying to do it in report template. Some curves are having expression in Y channel.
regards,
Durai
(3,191 Views)
Hello Durai26,
in REPORT you can get the maximum y value from all visible curves with this VBS function. It also considers constants that contain an expression.
function GetMaxYValueFromCurves(Curves)
  dim Curve, MaxValue, CurveValue
  for each Curve in Curves
    ' Only visible curves
    if Curve.Enable then
      if Curve.ShapeType = e2DShapeLineAndPoints or Curve.ShapeType = e2DShapeLine then
        CurveValue = Data.GetChannel(Curve.Shape.YChannel.Reference).Maximum
      elseif Curve.ShapeType = e2DShapeConstant then
        if instr(Curve.Shape.YConstant.Reference, "@@") > 0 then
          CurveValue = eval(replace(Curve.Shape.YConstant.Reference, "@", ""))
        else
          CurveValue = val(Curve.Shape.YConstant.Reference, Novalue)
        end if
      end if
      if IsEmpty(MaxValue) or CurveValue > MaxValue then
        MaxValue = CurveValue
      end if
    end if
  next
  GetMaxYValueFromCurves = MaxValue
end function
print(GetMaxYValueFromCurves(Report.ActiveSheet.Objects("2DAxis1").Curves2D))
(3,167 Views)
Hi AnJalpaka,
Thanks a lot for your suggestion, it was great to have some scripts like this.
It works fine for one of my template but unfortunately it throws error in my another template.
My report template refers to a particular channel and some situation there is no such channel exist in data portal. Since no channel exist, I am getting error in the below line,
is there a option to check for channel existing before fetching the value? How to skip these lines if there is no channel present in data portal?
Also, sometimes channel exists but it has NOVALUE in maximum and minimum properties. Even in these scenario, it throws error.
regards,
Durai
(3,139 Views)
Accepted by topic author Durai26
Hello Durai26,
The script can of course safeguard other circumstances, such as Novalues or non-existent channels. If the maximum of a channel is not known, it can be determined by the ChnCharacter command. If you don't want this, then take out the section with the call of ChnCharacter.
  dim Curve, MaxValue, CurveValue, Channels, Chn
        set Channels = Data.GetChannels(Curve.Shape.YChannel.Reference)
        if Channels.Count = 1 then
          set Chn = Channels(1)
          if IsNull(Chn.Maximum) then
            ' Calculate maximum value
            call ChnCharacter(Chn)
          end if
          CurveValue = Chn.Maximum
        end if
        else
        end if
      end if
      if not IsNull(CurveValue) then
        end if
      end if
    end if
  next
end function
(3,116 Views)
(3,077 Views)
