DIAdem
Fill 2D-report table dynamically
is there are way to create a 2D-Table in Report-View dynamically with the "Data.GetChannels"-Method?
I've got this starting position:
- in the Dataportal are up to 5 Groups (maybe less...)
- in each group is a channel "speed" and "time", which only has one value
No I want a 2D-Table in Report wich will look like this
Time100200Group3-Time-Value...
Speed 25 30 Value of Channel in Group3
more Channels 1 2 Value of Channel in Group3
I can do this by using textlists for each col, but the handling is very bad if a channelname changes.
Another workaround would be merging the groups temporarily to one group, but i hope there is a way to use Data.GetChannels("Group*/Speed")-Command.
Greetings,
Martin Kozlowski
(5,739 Views)
Accepted by topic author MartinKozlowski
Hi Martin,
In general I would discourage you from using channels with only 1 value.  In almost all cases it is preferable to store that information as a channel or group property.
Still you can get something like what you're asking for from your existing 1 value channels if you create table columns that are of type "Expression", configure the table to be in a Display Alignment of "Horizontal", set the scaling number of rows to the correct number of groups, and use expressions like these:
@@Data.Root.ChannelGroups(D2TabRow).Channels("Time").Values(1)@@
@@str(Data.Root.ChannelGroups(D2TabRow).Channels("Noise").Values(1), "d.dd")@@
Brad Turpin
DIAdem Product Support Engineer
(5,718 Views)
Hi Brad,
thank you very much. I almost forgot about the D2TabRow-Variable.
Greetings,
Martin
(5,707 Views)
