If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
06-14-2011 03:24 PM
I can't seem to get the FileDlgShow to work. I get an error "Variable is undefined: 'FileDlgShow' whenever I try to use it.
I am using version 10.2. The below is straight from Excercise 5-1 in the Diadem Advanced Course Manual.
Option Explicit
Call DataDelAll(1)
DlgState = FileDlgShow("C:\Excercises\DIAdem Advanced\","*.tdm")
If (DlgState = "IDOk") Then
Call DataFileLoad(FileDlgNameList(0),",")
Call ChnSmooth("[1]/[2]","/Smoothed",12,"maxNumber")
Call ChnPeakFind("[1]/[1]","[1]/Smoothed","/PeakX","/PeakY",5,"Max.Peaks","Amplitude")
Call DataFileSave("Results.tdm","TDM")
Call PicLoad("Smooth_2")
Call PicUpdate(0)
Else
Call MsgBoxDisp("Data loading has been aborted!")
End If
06-14-2011 03:30 PM
06-15-2011 04:45 PM
Hello!
The FileDlgShow command is not part of DIAdem 10.2. It was implemented later in Version 11. You have to use the bulky FileNameGet command instead.
Matthias
| Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
06-15-2011 04:55 PM
Thanks for your help!
I had a similar issue with FileDlgNameList - is FileDlgFileName the equivalent command?
Sherry
System Test Engineer
06-15-2011 05:04 PM
Hello Sherry!
Yes, you have to use FileDlgFileName. This string will contain all names and you have to split it on the | chracter to get an array.
Matthias
