DIAdem
Exporting LabVIEW data to DIAdem PDF Report
I am trying to save a PDF file generated in DIAdem to a file location that is specified in Labview. Meaning that this file location changes each time the report is generated. Currently the PDF saves to a designated file location that is in the script. I am fairly new to DIAdem but not to Labview. Any help would be greatly appreciated for some direction. I have attached a screenshot of the script as well as a screenshot of Labview code where the information is at.
Thank you for you time!
Danielle
(2,900 Views)
Maybe have the directory in a separate location (text file?) so both LabVIEW and DIAdem can easily access it?
(2,893 Views)
Accepted by topic author trevorlujan
Hi Danielle,
Are you trying to save the report to the same directory as the TDMS data? If so, you could just re-use whatever code you're using to find the TDMS data in the first place.
If you're having trouble finding the directory of your data in the first place, check out Searching for Data with a Script.
NickelsAndDimes
Product Support Engineer - sbRIO
(2,878 Views)
