DIAdem
Drawing ability in view
I would like to know if there is any possible to draw in view window? Like draw line between two points, draw circule...
For example:
I want to represnt my data by drawing>
Let's say i have channel of point1 and channel of point2 could i represnt the line betwwen those channel by drawing a line ?
(4,801 Views)
OzShimon,
You might be able to do this in the REPORT window by using a script to draw the line (or by drawing it with your cursor, if you wanted to do it manually) but I don't know of any way to do it in VIEW. Perhaps you could graph the data in some way to represent the relationship between the two channels?
(4,785 Views)
Maybe you could help me.
I need to demonstrate a plane remote control joystick movement: pitch,yaw,roll,throttle
in real time according to the graph cursor .
Do you have any idea how to do it?
(4,776 Views)
Hi Oz,
If you can get a CAD model of a joystick which has a mesh of points on it, you can show that time synchronized in DIAdem VIEW-- which can color, translate or (what you want) ROTATE points on the surface of a CAD model.
Brad Turpin
DIAdem Product Support Engineer
(4,773 Views)
