‎04-25-2005 10:34 AM
‎04-26-2005
06:20 AM
- last edited on
‎05-16-2025
04:06 PM
by
Content Cleaner
Hello marine boy,
this is looking uncommon.
Is the error occuring if you are using some special script or doing some special operations in the program or is it completely coincidentally? Are other applications crashing as well?
Inexplainable crashes quite often are based on corrupt memory. Maybe there is a problem with your RAM chips. There have been a lot of articles about that in computer magazines. Very likely DIAdem is using more of the RAM than all your other applications do thus accessing the corrupt bits - that could explain if DIAdem was the only application that is crashing.
You can try the newest DIAdem 9.1 Service Pack 2. Baybe it improves the satbility but if it is due to your hardware, what I assume, it is very likely that it does not make a big difference.
Mind that, it is a whole new installer - you need to deinstall previosly installed 9.1 versions before installing this one.
But try to replace the memory as well, or try the software on a different PC.
Hope this helps.
‎04-28-2005 03:04 AM
‎04-28-2005 04:26 AM
‎04-28-2005 09:00 AM
