DIAdem
Diadem View Window - Graph Axis Text Size
Hi.
Can anyone advise if it is possible to change the size of text used on graph axes when creating graphs in the View window.
Richard Norton
(2,554 Views)
Hi Richard,
I'm afraid not.  The DIAdem VIEW panel is designed for performance and quick ease of use.  If you want to specify an exact display format, then DIAdem REPORT is the panel designed for that.  The configuration dialogs are much more complicated, and it doesn't have to update graphs of millions of data points that are continuously changing, but it can display any fonts you want, etc.
Brad Turpin
Senior Technical Support Engineer
(2,512 Views)
