01-07-2020 02:18 AM
i got a channel and the property NoValues is set to "No"
But in help, its written that the values are integer numbers but in data portal i have string.
But when i manually add NOVALUE to numeric channel, after i logfilewrite the value and it returns me value "-1".
look at this, it returns me value which should not exist according to your help.
Solved! Go to Solution.
01-07-2020 01:35 PM
yes show up as text but it is numeric if you logfile it.
Also, looks like we have different help files... I'm on DIAdem 2019 64 bit service pack 1
01-08-2020 01:46 AM
OK, so it make sense. thanks.
i got 2017 version still.
i got problem with this function cause it returned me different state that it was in reality. but the problem i found was that the channel was not refreshed after some edits my script made.
I solved it by "refreshing the channel values" by calling this function, after the results matches the data values
Call ChnCharacter(chActive)
02-13-2020 09:21 PM
@gsklyr wrote:
yes show up as text but it is numeric if you logfile it. happy wheels
Thank you! It resolve my problem
