DIAdem
Diadem: Scaling is off when I am printing or exporting to PDF
Hi all!
When I am trying to export my reports to pdf (either via export or via print to pdf) the scaling is off. I tried every possible solutions. Checking "output print data to graphic" is working, but it is not a good solution for me.
I attached two screen captures. Report.png shows the report in diadem and pdf.png shows the resulting pdf.
If someone could suggest another solution I would be thankful.
Have a nice day!
Levente
(2,646 Views)
Hi Levente,
I tried to recreate the problem you had but printing to pdf worked fine for me. I've attached pictures of the printer and Diadem report settings I used. It's an easy thing to check if your settings are the same and if that fixes it or not. If it doesn't help then we can look for some other solutions.
Also, in your pdf viewer, can you check what paper/page size it is using? Maybe it is not letter size?
(2,629 Views)
Hi!
Thank you for your fast reply!
Interestingly I too couldn't replicate the problem. It just worked fine with the same settings that failed before.
My colleague told me that he too experiences the bug occurring only some times. I will try investigating further when I encounter it again.
Have a nice day!
(2,619 Views)
