DIAdem
DataFileLoadSel memory handling
I am taking small bits and pieces from various rather big TDM-files with the DataFileLoadSel command. Strangely enough the memory consumption increases rapidly with each file being handled until it reaches almost 4 GB. Then the script stops with an out of memory error (though I still have 12 GB RAM available).
1. Is there a limitation for Diadem memory usage up to 4 GB?
2. It seems to me that Diadem is loading the whole file into the memory although I only take out a small data set. Is that correct and how can I prevent the from happening? "Load" or "Register" do not make any difference in that behaviour.
Thanks for your input.
Phex
(6,084 Views)
Do you have large string channels in your tdm file?
How many values do the channels have?
Which DIAdem Version is used?
Background: DIAdem is a 32bit application so it makes use of 4GB RAM. On the other hand it is capable to swap loaded data to external swap so there shouldn't be a behavior like this. At all Load and Register should show different memory consumtion behavior.
(6,063 Views)
Thanks for your answer.
I am running DIAdem 2012 and I only have float values in my channels with about 200 each, so nothing abnormally big. When I run the DataFileLoadSel in a loop on all my files, i can observe that the memory constantly increases proportional to the size of the whole file (although I only load 4 channels of each). At 4GB the script stops without displaying an error message and DIAdem basically needs a restart. It is not possible to work properly in any module anymore and a forced restart is required. The event viewer shows a .NET framework error (ntdll.dll) followed by the Application Error of DIAdem. I already tried a reinstallation of either .NET and DIAdem, but it did not resolve the problem.
Any idea what I could check as well?
(6,055 Views)
Can you offer some more information?
  • How many files
  • How many channels does each file contain
  • How many channels per file do you want to load
  • How big is the tdm file, and how big is its related tdx file
Can you try the following:
  • Settings->options->General
  • Pick Data Area and set it to Swap out data : Always
  • Run your script with "Load"
The maximum amount of DIAdem channels is 65000. To you strike this barriere?
Maybe putting
BulkDataLoadingMode   = eBulkDataLoadingImmediately
 as first line to your script and using "Load" may help too.
(6,042 Views)
Accepted by Phex
please start the NAVIGATOR Settings dialog and switch the option "Load bulk data on modification of channel data" to "Always load bulk data" and please try again. When using TDM-files with many short channels, this setting will support your application in a better way.
Instead of "Register" please use "Load" in your case.
Greetings
(6,034 Views)
Switching to "Always load bulk data" did it! Thank you so much.
For your information:
My biggest file I loaded with DataFileLoadSel contains 22000 channels each with about 200 values giving a size of 63MB for the TDM and 630MB for the corresponding TDX. The swap setting did not have any influence.
(5,998 Views)
Thanks for the information and Greetings
(5,990 Views)
