DIAdem
DAC: Script-block with a new size limit in DIadem 9.1 ?
The Script-block of DIAdem 9.1 DAC seems to have a new limitation in size of the implemented script-file. The limit is about 16 KB.
Run the two attached DAC-demofiles. "Script_test2.dac" works but "Script_test1.dac" cause a error message when translating implemented scriptfile. The only difference between the two files is the number of comment lines in the vbs-file ("Meanvalue1.vbs" or "Meanvalue2.vbs").
Change the number of comment-lines. The error message will alter but every message is wrong.
The effect don't occur in Diadem 8.1
It's only a demo here, but in real world I can't use "long" scripts used in Diadem 8.
- Was the script-translator (?) changed beetwen the two releases?
- May I use the old
one in Diadem 9, or any other workaround?
I can't believe, that I am the only one who tried to work with "long" script files in Diadem.
Martin Bohm
bohm@a3m.com
(3,698 Views)
thx for the demo - we are still working to solve the problem...
regards,
Thomas Sandrisser
(3,693 Views)
@Martin
No, you are not the only one - I have exact the same problem.
Michael Symonds
(3,532 Views)
Hi all,
concerning long DAC scripts there was a problem that we fixed. Please download this fix from:
http://digital.ni.com/softlib.nsf/websearch/D9AF63607886EFD986256F6B004131EC?opendocument&node=132060_US
I hope that will solve the problem.
Greetings
Walter
(3,530 Views)
Hi Walter!
Yes, thanks - it solved my problem 🙂
Michael Symonds
(3,511 Views)
