â04-08-2019 06:48 AM
Hallo, I have an XTable showing channel number, channel name and unit of measure. The unit can be freely chosen by the user, but I want it to be chosable among 2 options, so I want a combobox in each row of the table. How to do that?
More over: How do I set the default value of a combobox? For example: if the unit of measure can be chosen among "bar", "Pa" or "atm", I want to show Always as default value "bar".
â04-08-2019 01:34 PM
Double click the column name and you should get this configuration window:
â04-09-2019 04:56 AM
Thank you, very useful!
Mattia
â05-09-2019 09:23 AM
Follow the link below for a complete example of using a ComboBox in an XTable. A custom class is used to make it easier to work with a ComboBox control within an XTable.
http://www.savvydiademsolutions.com/dialog.php?topic=XTable-class-controls
