DIAdem
Coverting Text Channel to Numberic using Dict.Add function
I have multiple channels that have a text value to them and I was using a Dict.add function to change the values to a Number so it can be plotted linearly.  However I have had to create a seperate function for each channel in the data set.  I want to generalize it more so it will go out and look a all the channels and compare the values to the dictionary's already created.  I have attached a sample form of how I currently am doing the change and I have played with a new form called TxtToNum.vbs that is more generalized.  I have 6 dictionary's that I am using in total as well if that plays into the task.   I don't do a lot of script work and could really use some help.
Thanks - J
Message 1 of 15
(8,716 Views)
I continue to try and play with this but can't seem to get it.  I am missing the logic somewhere.  I am trying to take a text value and compare it to my dictionary and then set the number in the text value's place
Like "On","1"  So my channels would end up being a numeric channel and my "On" would turn into a "1" according to my dict3.
UGGGG!
Message 2 of 15
(8,701 Views)
Ok, got it to work but now I have a TEXT channel still and need to convert it to numeric values.  How can I add that to this script?
Message 3 of 15
(8,690 Views)
Hi Jcheese,
Unfortunately there isn’t a direct way to convert a string/text channel to a numeric channel that I can find.
If you’re just pulling out individual values,
CStr() converts a numeric to a string. CInt() or CDbl() will convert a string to an Integer or a Double.
If you need to convert the whole channel, you would probably need to create a second channel, initialized to the same length as the Text channel, and then loop through the channel. Pull the text value out of the existing Text channel, use one of the functions above to convert it to a number, then set the value at the same index in the new channel.
Here’s a reference for creating a channel and setting the values:
http://zone.ni.com/reference/en-XX/help/370859J-01/procauto/procauto/procauto_group_channel_generate...
Kelsey Johnson
Applications Engineering
Message 4 of 15
(8,675 Views)
Hello JCheese,
please try this :
Dim   sgCmd
sgCmd = "ch(""#1"") = Val(ch(""#1""))"
sgCmd = Replace(sgCmd,"#1","MyChannelname")
Calculate(sgCmd)
The text MyChannelname needs to be replace with the name of the channel you want to convert
This uses the DIAdem "VAL" operator on the whole channel
Message 5 of 15
(8,663 Views)
Hello and thanks for the reply,
I tried the script you copied and it changing the channel to a numeric channel however it turns all my values into "NOVALUES"
My attachment that I have on this post is a working script that I am running and I wish to add the conversion factor into that script so as it converts it to the dictionary key it changes the channel to a numeric channel.  Does anyone know how I could write that to work?  I am not that familiar with script to write this kind of file.  I have added my old file that I used which did make a seperate channel and put in the values like I want but it takes a long time to run.  I am going through sometimes thousands of rows of data.
Message 6 of 15
(8,650 Views)
Hello JCheese,
running your script I saw that for those channels where you got NoValues, your mapping from text to the desired Integer didn't work. So after your "ConvertTxtToNum" you still have text in the channel which is like "Reading Not Available" in channel 49. It looks like your mapping is incomplete. Val("Reading Not Available") returns NoValue. Do you plan to add teh missing text/Value pairs in your map or do you want those strings to be mapped to a standard value ?
Message 7 of 15
(8,645 Views)
JCheese,
to better explain whats going on:
If you would change your function to this :
Function ConvertTxtToNum(Channel)
  Call Channel.ChannelGroup.Activate
  for t = 1 to Channel.Size
  IF Dict3.Exists(ChT(t,Channel.Name)) THEN               ' Compares value in channel to value in dictionary
  ChT(t,Channel.Name) = Dict3.Item(ChT(t,Channel.Name))   ' changes the Key to the Item in the dictionary
  Else
    ChT(t,Channel.Name) = "0"
  end if  'dict3
  next
End Function ' ConvertTxtToNum()
 You will find that the functions using "Val" works as expected adn doesn't create NoValues anymore
Message 8 of 15
(8,643 Views)
If a value is not present in my dictionary, then I would like it to be set to 0.
Message 9 of 15
(8,642 Views)
Accepted by Jcheese
The following should do what you want:
' Text to Numeric Channel
if programrevision > 1129 then
  Dim Channel,State,Dict3,t,TXT1
    IF Data.Root.ChannelGroups(1).Channels.Count > 0 THEN
      FOR Each Channel In Data.Root.ChannelGroups(1).Channels
        IF Trim(UCase(Channel.Properties("DisplayType").Value)) = "TEXT" THEN
        Call ConvertTxtToNum(Channel)
        Call ValChn(Channel)
        END IF
      NEXT ' Channel
    END IF ' Any Channels at all
END IF ' Program Version
  Else
  end if  'dict3
  next
Function  ValChn(oChannel)
  Dim   sgCmd
  Dim   ChnNumber : ChnNumber = oChannel.Properties("number").Value
  sgCmd = Replace(sgCmd,"#1",oChannel.GetReference(eRefTypeIndexName))
  Calculate(sgCmd)
End Function
Message 10 of 15
(8,639 Views)
