DIAdem
Check if DIAdem script started directly
is there a way to check if DIAdem script started directly?
In Python there is:
if __name__ == "__main__":
    main()
With this functionality I could separate functionality for the script when it is imported by another script and when it is run directly.
(2,764 Views)
Accepted by SeryDavid
There is no direct way but you could use SubSequence and some error handling.
bMain()
sub bMain()
  on error resume next
  call SubSequence() : if 0 = err.number then exit sub
  on error goto 0
  MsgBox "Execute main"
end sub
Here are two example scripts to check
a.vbs
Option Explicit
scriptinclude currentScriptPath & "b.vbs"
call b()
b.vbs
Option Explicit
sub b()
  MsgBox "b called"
end sub
bMain()
sub bMain()
  on error goto 0
end sub
(2,742 Views)
