DIAdem
Case sensitive string variable?
I use the following code to determine whether I am opening a DAT file or a TDM file. Some of it is complicated by a bug in 2010 but that is not relevent for this particular problem. Up until today it has worked perfectly, probably because the TDM files I have been opening were written using code from the same autosequence. Today I was opening files saved by DIAdem using the standard save as toolbar button.
T2 = NameSplit(T1,"E") ' extract file extension
if T2 <> "TDM" then 'case sensitive??
CallDataLoadHdFile(T1) 'Temporary fix from NI until DataFileLoadSel problem is fixed
CallDataLoadSel(DATADRVUSER&T1, ChList_, 0) 'Temporary fix from NI until DataFileLoadSel problem is fixed
' Call DataFileLoadSel(DATADRVUSER&T1,T2,"[1]/["&ChList_&"]","") ' Load selected data channels from next file 'Commented out by SA 8/6/11, as it doesn't work in 2010
else
CallDataFileLoadSel(DATADRVUSER&T1,T2,"[1]/["&ChList_&"]","") ' Load selected data channels from next file
endif
The code failed because the file I was opening had the extension tdm, and thus the value of T2 was "tdm". I couldn't believe it but I wondered whether the if...then loop was case sensitive to the value of T2. It was... When I changed the second line of code as follows (i.e. lower case tdm) it worked.
if T2 <> "tdm" then'case sensitive??
It seems that when DIAdem saves files it applies a lower case extension but my code has applied uppercase letters. For reasons of backwards compatability I can't really change my code to save with lower cases.
I've tried using:
if T2 <> "TDM" or "tdm" then'case sensitive??
but that doesn't work.
So, my question is: how do I correct the 'or' statement so that it works, or is there a function I can use to make the if...then loop and/or T2 case insensitive?
Thanks.
(5,739 Views)
Try InStr for comparing instead:
T2 = "TDM"
If InStr(1, T2, "tdm", vbTextCompare) <> 0 then
 MsgBox "Found TDM"
end if
(T2 contains capital TDM whereas Instr used lowercase tdm for comparison....)
(5,728 Views)
Thank you!
(5,718 Views)
Another way to solve this kind of problem is to upper case (or lower case) the string prior to the check.
if ucase(T2) <> "TDM" then
(5,601 Views)
