DIAdem
Bus log conversion of XNETExample - missing cluster options
I discovered a problem performing a bus log conversion of the DIAdem 2021 example bus log file 'XNETExample.tdms' and the bus log database file 'XNETExample.xml' using the Bus Log Conversion dialog.  The dialog that presents the three cluster's options is empty.  See attached images for a complete demonstration that anyone can run on their DIAdem installation.
I'm running DIAdem 2021 v20.0.0f8135
Message 1 of 1
(1,062 Views)
