DIAdem
Average
i have a simple problem.
How can i get the average of a row.
For example: i have the numbers  2 4 6 and 8 the average of this is 5
Is there a simple methode in Diadem?
greetings
ni262
(3,736 Views)
Hello NI262,
You can use the Descriptive Statistics function. In the parameter dialog you can choose between a channel oriented (columns) mode or row oriented (one line of certain channels) mode. If you choose the channel mode you can optional define a block of values (begin and end in the channel) which should be calculated.
Greetings
Walter
(3,728 Views)
Hello Walter,
simple solution for a simple problem...
many thanks
greetings
NI262
(3,722 Views)
