DIAdem
Accessing Custom Channel Propertiesfrom an External VB Script
I'm am updating an inhouse VB script that opens a datasets, and generates an ISOMME dataset for processing. (
The script creates an instance of Diadem objects and iterates the channel collection, and exports the raw data into the ISOMME format.
I need to update my script to allow creation of and reading of custom channel properites.
I can do this easily within a VB script running inside DIADEM (see below)
Dim i
Dim sChanName
Dim sChanComment
For i = 1 To GlobUsedChn
sChanName = CN(i)
sChanComment = CC(i)
'Add custom property
' Write custom properties SensorID and Sensitivity
if i = 2 Then
Call Data.Root.ChannelGroups(1).Channels(sChanName).Properties.Add("SensorID", "ID1234ABC",DataTypeString)
Call Data.Root.ChannelGroups(1).Channels(sChanName).Properties.Add("Sensitivity", 0.123456789,DataTypeFloat64)
End if
Next
sChanName = CN(i)
' Read custom propertiees
if Data.Root.ChannelGroups(1).Channels(sChanName).Properties.Exists("SensorID") Then
LogFileWrite "Channel " & sChanName & " :: SensorID=" & Data.Root.ChannelGroups(1).Channels(sChanName).Properties.Item("SensorID").Value
End if
if Data.Root.ChannelGroups(1).Channels(sChanName).Properties.Exists("Sensitivity") Then
LogFileWrite "Channel " & sChanName & " :: Sensitivity=" & Data.Root.ChannelGroups(1).Channels(sChanName).Properties.Item("Sensitivity").Value
End if
Next
But I wish to do this via an external VBScript that instanitates an instance of Diadem,how would I do that?
I can access Channel names, but cannot get to the custom properties. Have a sample of my script below. The bit in red does not work as the properties/methods I would like to access are not available. Is there a way for me to do this?
    Set oDiadem = CreateObject("DIAdem.TOCommand")       
    Set oDiademSheet = CreateObject("DIAdem.TODataSheet") 
    oDiadem.CmdExecuteSync ("DataDelAll(1)") 
     nDiademStatus = oDiadem.TextVarSet("T3", sDataSet)
     oDiadem.CmdExecuteSync ("DataLoad(T3)")
      'Use the diadem command GlobUsedChn to recover the number of channels       
      oDiadem.CmdExecuteSync ("L3 := GlobUsedChn")    
      'Get the value of GlobUsedChn from L3 and put it into nChannelCount)
      nDiademStatus = oDiadem.TextVarGet("L3", nChannelCount )
      For i = 1 To nChannelCount 
            If Not oDiadem.bInterfaceLocked Then
                nDiademStatus = oDiademSheet.ChnNameGet(i, sChannelName)
                nDiademStatus = oDiademSheet.ChnCommentGet(i, sChannelComment)            
            End If            
            If sChannelName = "13APILBOMIMIACXP" Then 
                Set oTargetChannel = oDiademSheet.Data.GetChannel("13APILBOMIMIACXP")
                oTargetChannel.Properties.Add  "'SEnsitivity'" , 123.4567, DataTypeFloat64                
            End If 
        Next    
    End If 
(4,319 Views)
Have you confirmed that it is ever entering the sequence in red? From a quick look at VBS operators I think the issue is that the if statement needs an extra = sign as right now it is assigning the value rather than comparing.
https://www.tutorialspoint.com/vbscript/vbscript_operators.htm
What environment is the VBS script actually running in? They're may be debugging tools within this environment to check for things like, whether the oTargetChannel actually has any channel data assigned to it.
Ed
(4,245 Views)
Accepted by topic author Onkar
Hi
My approach was incorrect. Here is a solution for anyone that wishes to add custom properties via VBscript running outside of Diadem.
Dim oData
Dim oDiadem
Dim oDiademSheet,
Dim i
nDiademStatus = oDIAdem.VariantVarGet("Data", oData)
For i=1 To nChannelCount
    If Not oDiadem.bInterfaceLockedThen
        nDiademStatus=oDiademSheet.ChnNameGet(i,sChannelName)
        nDiademStatus=oDiademSheet.ChnCommentGet(i,sChannelComment)
    EndIf
    'Here are am interested in setting the ID For only one particular sensor. 23 Is a constant for String
    If sChannelName="13APILBOMIMIACXP"Then
        Call oData.Root.ChannelGroups(1).Channels(sChannelName).Properties.Add("SensorID","ID1234ABC",23)
    EndIf
Next
(4,226 Views)
