DIAdem
3D table method
Hi. I am sungbae chi
AE from NI korea.
I want to make 3d table from my raw data.xls attached.  Then I don't know how to arrange to report.xls attached.
I've tried to use '3D table with Labels' in 'REPORT'. But, there is no option  to build what I want to.
for example, I just want plot 10 Points(x,y,z) [In excel, 3*10 array]. but, In DIAdem report, There should be '10*10*10' points made.
Is there anyone knows how to?
(4,085 Views)
Hi Chisbae,
Do you just want to transform your input table (on the left) into the matrix table (on the right), or do you try to plot it ? I am unclear if you already succeeded in reading your data correctly to have it in the Data Portal or not ?
CLAMaxime -- Kudos are a great way to say thank you
(4,067 Views)
Accepted by chisbae
Is that what you want ?
If yes, you can use the Convert Matrix function in ANALYSIS to convert your three channels into a matrix format and then just drop the newly created channels on your 3D table with labels 🙂
(4,063 Views)
Hi.
Thank you. It's so clear and fast answer for me.
It's solved
Sungbae chi
(4,035 Views)
