DIAdem
2D Plot Channel Names
Oups sorry, I missed that info... My bad !
I'll try to figure out something else then 🙂
CLAMaxime -- Kudos are a great way to say thank you
Message 11 of 17
(1,508 Views)
I'm still struggling with this, can anyone help?
Message 12 of 17
(1,488 Views)
Have you explored using the GraphObjChnNameGet command? It looks like this should return the name of an object in a report, being a curve in your case.You may be able to loop through the curves in your report to see if the specific one you're looking for already exists, then add the channel maximum from there
Alex C.
Applications Engineering
Message 13 of 17
(1,475 Views)
Some editing is still needed but that should be a good starting point.
Message 14 of 17
(1,471 Views)
Can you paste the code into a reply?
Message 15 of 17
(1,463 Views)
Accepted by topic author BrianCT
Sorry, forgot you could not download anything...
'-- VBS script file
'-- Created on 05/09/2018 13:37:04
'-- Author:
'-- Comment:
Option Explicit  'Forces the explicit declaration of all the variables in a script.
Data.Root.Clear
Call DataFileLoad(CurrentScriptPath & "EXAMPLE.TDM")
Call REPORT.LoadLayout(CurrentScriptPath & "EXAMPLE.TDR")
Dim oSheet : Set oSheet = REPORT.Sheets("Test")
Dim oChart : Set oChart = oSheet.Objects("Chart")
Dim oCurves : Set oCurves = oChart.Curves2D
Dim oChannels : Set oChannels = Data.Root.ActiveChannelGroup.Channels
Dim channel, oMyCurve, count, curve, name
count = 1
For Each channel In oChannels
  For Each curve In oCurves
    name = split(curve.Shape.YChannel.Reference, "/")
    If(name(1) = channel.Name) Then
      Set oMyCurve = oCurves.Add(e2DShapeLine, "New" & count)
      oMyCurve.Shape.XChannel.Reference = "[1]/Time"
      oMyCurve.Shape.YChannel.Reference = "[1]/" & channel.Name & "_Mean"
    End If
  Next
  count = count + 1
Next
Message 16 of 17
(1,460 Views)
Thanks for your help, works great!
Message 17 of 17
(1,432 Views)
