Hi, I had a version of DasyLab 11. I have a problem with iOtech Personaldaq 3000. I had install driver form CD, and when i want to go measurement -->select driver --> then i select iOtech Enhanced DASYLab Driver. then it's message to restart. I restart DasyLab, but Driver is not loaded. I can't install it. Please Help mi to resolve this problem.
What operating system?
If it's 64-bit, then the CD may not have the correct drivers. Dpwnload the latest from http://www.mccdaq.com/software.aspx.
Unplug the device and uninstall all PersonalDAQ drivers first.
Scroll down to the IOtech downloads, select the correct folder, and download and install the dasylabdaqcom2setup.exe file to install.
Plug in the device, allow it to redetect before starting DASYLab again.
Then go to the Measurement menu, Hardware Setup, Driver, and add the device in.
I 'm done all your's step and this not working also. I uinstall all ( daqCOM, DASYLab support Drivers, DaqView in control Panel) then i go to te link you send take IOtech drivers, take PersonalDaq 3000 series, download and install dasylabdaqcom2setup.exe. After that plug to USB PersonalDaq 3000, then start DasyLab go measurement, hardware setup , driver and again doesn't work (message - no hardware driver loaded). System is Windows7 x86. What else can i do.
When i go to Help - About DasyLab - in Version tab Driver DLL and Virtual driver is null (---).
The next step is to call or email Measurement Computing for direct assistance.
