DASYLab
file write
How can I take data, write it to an ascii file then at an arbitrary time in the future write another set of data to the same file?  I keep getting file sharing violation errors.
(6,586 Views)
Is this file structure you are working with using the DASYLab software? Or, are you working with LabVIEW? Does you data acquisition work correctly in Measurement and Automation Explorer?
Cheers,
Patrick Corcoran
Application Engineering Specialist | Control
(6,574 Views)
You cannot have the same file opened more than once.
If using DASYLab only, you can APPEND to the file.
You cannot read and write to the same file without a sharing violation.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,489 Views)
