DASYLab
data trigger to solid state relay
I would like to take 2 channels from a data trigger and have them hold a solidstate relay closed until the trigger event.
Any idea's what module could I use to perform this task.?  Thanks. Kent
Message 1 of 13
(7,983 Views)
Kent,
I need a bit more explanation. Is the data trigger the DASYLab Data Trigger module or is it a Digital Input?
...until the trigger event.... what trigger event?
I would look at the Latch module or the FlipFlop module.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 2 of 13
(7,978 Views)
Sorry ,It's a dasylab data trigger module setup to trigger within the limits I have set.
The data trigger works on my status indicators, green for good, red for bad . When the staus is
green I require a NC solidstate control relay and when it goes red I require that relay to open.
Message 3 of 13
(7,976 Views)
I tried using a digital output but I believe because I'm using the analog input to get my required speed this is not possible. Is there a way of programming and
wiring an analog output to control this solidstate relay.
Message 4 of 13
(7,975 Views)
Which hardware are you using?
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
Message 5 of 13
(7,970 Views)
Hi Tom
USB-1208FS
   Analog subsystem
5000Hz / 100 samples/block
Works great at my speed requirement. CJ and Jeff helped me out of a bind when they suggested going to analog instead of the slower digital sub system.
But I still require a way to get a signal out to my machines solid state relay for a stop command when the data goes out of range and status goes red.
Message 6 of 13
(7,968 Views)
To my understanding, I also have a 1208FS in my stock, you should be able to connect it with a digital output very easyly.
The manual would explain it how to do it wire it.
Obviusly, do not expect a super fast reaction but it should be good enough.
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Message 7 of 13
(7,963 Views)
I have tried to add a digital output but it seems to slow down the analog input also.
I will test further this way to see what's really going on. The digital output speed is
not as big a factor in this experiment.  Thanks Kent.
Message 8 of 13
(7,961 Views)
That is strange, when you're done with the design, post it and maybe we can quickly test it
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Message 9 of 13
(7,959 Views)
It doesn't appear that It will let me use a digital output with out changing my scan rate.
Message 10 of 13
(7,957 Views)
