DASYLab
block size
Good Morning! I'm trying to open an ASCII file, which was collected through MegaWin software. However, when trying to open I get the following message: "The Set block size is larger than the number of lines in the ASCII file". I need to run the file in order to pass a filter on data from electromyography. If anyone can help me I will be very grateful!
(5,973 Views)
The Read Data module defaults to using the Driver timebase. If you don't have enough samples to fill a block, then you encounter this error message.
Click on the Ascii options setting to change the sample rate/block size to one that reflects your data. You need a block size of more than 1 to use the digital filters.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(5,968 Views)
Ok! Thanks for your help and attention!
(5,951 Views)
