DASYLab
X/Y chart when X is a fixed array of 24 numbers
Hello all,
Every second I read twenty four values which are my Ys. I also have a fixed array of twenty four Xs. Each Y correspond to specific X. How do I plot Y versus X ? The plot should be updated every second as new Ys are measured every second. Xs are fixed and never change. I suspect I need to use "X/Y Chart" but could not figure it out after spending half a day on it.
Any suggestions would be appreciated.
Thank you, Pavel
(3,822 Views)
Thanks to HW -- here is an example that uses two sets of sliders to create the values, and multiplexes them together.
The X-Axis sliders could be hidden in a Black Box, for example.
See the attached DASYLab 2016 example.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(3,805 Views)
Thank you very much, CJ.
(3,784 Views)
