05-01-2012 02:50 PM
I am assuming; since I cannot do it; that you cannot change the display range of a Chart recorder by use of a variable. If there is a way I would love to know how.
Thanks!
Solved! Go to Solution.
05-01-2012 06:17 PM
One way to determine if you can use a global variable is to right-click in the parameter field. If Global variable is offered in the context menu, then you can use a variable there.
You can use a variable for the Y-axis from/to parameters.
You cannot use a variable for the X-axis Display range parameter. This is because DASYLab needs to know how much memory to allocate at the start of measurement.
