DASYLab
Using a Global Variable for Chart recorder DisplayRange Input
I am assuming; since I cannot do it; that you cannot change the display range of a Chart recorder by use of a variable.  If there is a way I would love to know how.
Thanks!
(6,183 Views)
Accepted by topic author Falizar
One way to determine if you can use a global variable is to right-click in the parameter field. If Global variable is offered in the context menu, then you can use a variable there.
You can use a variable for the Y-axis from/to parameters.
You cannot use a variable for the X-axis Display range parameter. This is because DASYLab needs to know how much memory to allocate at the start of measurement.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,181 Views)
