DASYLab
Universal filter behaviour
try attached DSB file
I created the DSA with 2020 and maybe there any incompatibilities...
cheers,
thomas
Update: Added DSA version
Message 11 of 18
(2,960 Views)
Hi again Thomas,
Now it works fine! Great example for me who are not so familiar with filters. I attached one example where you can see now raw data (PU 50) and next one is filtered by CFC 180 (I had once possibility use diadem for while). Third one is filterd by butterworth 4-order and last by example yours but I of course change those values to corresponds CFC 180. Seems to working pretty well otherwise but it increases signal value. Do you have any hint for that?
Br Mika
Message 12 of 18
(2,957 Views)
Hi Thomas,
I found one mistake in formula (ao) whein I corrected that it funcs well. Some short delay there is still but it is half shorter compare to butterworth.
Big thanks to you Thomas now I can use this universal filter module
br Mika
Message 13 of 18
(2,950 Views)
Hi Mika,
just a guess:
the given filter is just the two-pole version with phase shift. data has to pass the filter a second time in reverse direction to compensate for phase shift. maybe this removes gain also.
br,
thomas
Message 14 of 18
(2,949 Views)
Hi Mika,
great - that was a typo I guess.
Attached fixed version.
Br,
Thomas
Message 15 of 18
(2,945 Views)
Hi Thomas,
Is there possibility pass data in reverse order in Dasylab?
Br, Mika
Message 16 of 18
(2,943 Views)
br, Mika
Message 17 of 18
(2,942 Views)
Hi Mika,
afaik this not possible today. Would you like to spend some bucks so that we get some founding on it? the digital filter module would get an option for zero-phasing - which does this reversal kind of thing...
Just drop us an email @ info@measx.com .
br,
thomas
Message 18 of 18
(2,932 Views)
