DASYLab
Trigger based on maximum value of signal
Hi, I'm a student and have just started using DASYLab. How can I make it triggers only when the maximum value of a signal is within a certain range?
The input signal is an impact from an impact hammer. Previously I used a Pre/Post trigger, it triggers whenever a data point falls within the trigger range, but I want it to trigger only when the maximum value falls within that range.
Thank you.
(3,440 Views)
You can compute the Maximum using the Statistical Values module or the Min/Max module.
I would use Min/Max to detect the peak, and release a TTL trigger, rather than the data value.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(3,410 Views)
