DASYLab
Time increment
to TomRizzo
I need it because I only need high sampling rate for the first  few hours. While the experiment can last several days. Therefore, if I used a very high sampling rate, there will be to much data and might consumed to much space on the computer hard disc. by having different sampling rate and block it will be more efficient.
Message 11 of 18
(4,502 Views)
Ahhhhhh
In that case we need to use different criteria and averaging to reduce the sample rate and frequency.
The easiest way would be to use different files for the different sample rate but could be done with ASCII files as well as DDF not sure if you can with other types.
Which file format were you planning on using?
Tom
PS
You really need to talk to your professor to upgrade to V12 🙂  I'm sure that your local rep would have something for Universities discounts Smiley Happy
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
Message 12 of 18
(4,500 Views)
I used ASCII.
Ow, how do you use different criteria and sample averaging?
Currently I used a different file by using 3 write module. But, If I stop one of them(from writer module option or using stop module), the whole program would stop....is there anyway to stop only one of it?
yeah...I think I'll try to talk to him about that tomorrow...Is it easier to do that in V12?
Message 13 of 18
(4,497 Views)
Accepted by topic author Martin wijaya
I feel rather strongly that my proposed solution will resolve your problem, and that it's very likely to work with DASYLab V5. It's similar to an example that we included in our original Getting Started guide, and works independently of your sample rate. Your base sample rate (where you collect and display the data on the screen, before reducing it for the file) should be at least twice, and probably 5-10 times faster than the fastest storage rate. That ensures that the Generator module can actually pulse.
This is an image of the pulse signal that you specified.... The very dark at the left is the high speed, then the lighter area is the moderate speed, followed by the very slow rate. The dark lines are an artifact of the aliasing that is happening on the image, and not a reflection of the data rate.
I've attached the data file that this produced. I ran for a simulated 10 hours, so that you have a few data points at the end to show that it slowed down to one sample per hour.
My raw sample rate was 100 Hz.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 14 of 18
(4,493 Views)
You can find the DASYLab 6 QuickStart, which should apply to V5, at www.dasylab.com in the Downloads tab, under Information, on page 2.
DASYLab in less then 30 days (Hands-On Guide Version 6, English)
Message 15 of 18
(4,492 Views)
OW...thanks so much... I will learn again how to make just like you. That is exaclty what I want.
Message 16 of 18
(4,489 Views)
Dear cj
In my daisy lab, when I click the generator, there are several options that I have to choose (without modulation, amplitude modulation, frequency modulation, etc). Can you tell me what type of generator that you used?
the signal switch module is the same like time slice right? isn't this module only changes the chanel that I used?in which part the sample rate is altered?
I tried to see generator module under "read global variables" option. How to control the sampling rate by using global variable?
I have read the module that you reccommend to me, but I still a bit confused because in that book, they ussually adjust the sample rate based on the amplitude instead of duration.
Regards
Martin Wijya
Message 17 of 18
(4,481 Views)
If you go back to my original post,
Generator01 is generating a constant. It is an ordinary generator, without modulation.
To use Gl. Variables, you can change the Generator to read Global variables.
The constants are the desired RATE in seconds (1, 30, 3600, etc)
Arithmetic is Arithmetic 1 channel, and is doing the "Inverse" or "Reciprocal" function, 1/input
The channel value at this point is a frequency in Hz.
Signal Switch is the Time Slice module, time based. Each channel defines the duration of the step (30 minutes, 5 hours, forever = 999999 hours). It selects which input to send to the output.
The Generator00 is a FREQUENCY modulated generator, where the mode is "Pulse" or "impulse" and the amplitude is 5 (TTL High). This will create a timing signal, with a pulse at the specified RATE, using the frequency computed above.
The data reduction is done by the RELAY module. It releases one data point for each TTL High pulse that the Generator00 outputs. Otherwise, it discards the data.
The output of the Relay is the reduced data stream... no averaging or separate needed.
Message 18 of 18
(4,468 Views)
