DASYLab
TCP configuration
Hi guys
I would like to get your help to solver the configuration is request to get the values via TCP. I have power meter with RS485 output type Modbus RTU and I can't to get the main values from meter in order at the next list of configuration
I am trying to do a connection using ICom Input in DasyLab and I would like to get help to configure Modbus TCP/IP
I have tried to get them with this format but I can’t get the value exactly, the system get some value but I can’t know as interpret to get exactly the measures
Please could you help me to configure the data format and data request to get the information
Message 1 of 11
(8,623 Views)
Modbus should just work if the device is visible as an RS232 channel.
Why are you using Internet methodology ?
You likely need to convert 485 to 232 - easy enough.
Use Modbus DasyLab control objects and off you go.
Sort out little issues like the base address of the device.
I used this system recently with DasyLab12 and was straightfarward.
Good luck.
Dave the Rave
Message 2 of 11
(8,592 Views)
Hi Dave
I need to get information from meter via Internet, What si your recommendation I have a converter RS485-TCP/IP connected to power meter
Message 3 of 11
(8,584 Views)
Have you looked at the Modbus module? TCP/IP support was added with V11 SP1.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 4 of 11
(8,579 Views)
Yes I have tried with this module but it doen't works, sent error of connection. I have a DDNS to connected the meter to my ADLS becuase my IP isn't fixed
Message 5 of 11
(8,577 Views)
You should probably contact DASYLab support directly.
See the support page at www.dasylab.com
I've found Modbus devices to be a bit "picky", and it's trial and error to find the correct settings.
You don't mention the version of the software - the DASYLab 12 Modbus TCP/IP seemed to work better than V11.
Message 6 of 11
(8,572 Views)
I have v11, is possible I can work it or I needed an update
Message 7 of 11
(8,562 Views)
Make sure that you have DASYLab 11 SP2 from www.dasylab.com, or try the evaluation version of V12.
DASYLab 11 Service Pack 2/English
ftp://ftp.mccdaq.com/Archive/DASYLab/DASYLabV11/DLV11_SP2/ENG/DASYLab11.0SP2e.exe
Message 8 of 11
(8,553 Views)
The best way to use MODbus in our experience is to use a OPS server.
We also found one at around $500.00.
This will give you a better way to comunicate with your device and more reliable.
The OPC module in DASYLab works very as well
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
Message 9 of 11
(8,546 Views)
Hi Tom
please could you tell me as I can configure OPS server. I am new on this new protocol. Thanks
Message 10 of 11
(8,540 Views)
