DASYLab
Ignoring short peak values
Does anyone know how to remove those over certain limit values from signal  which duration is for example below 0.1 seconds? So I just want to find those max values which duration is over 0.1 seconds
Thank in advance
-Mika
(2,541 Views)
This sounds like the Sample Trigger module.
You will need to experiment, to see how to use it. It will output a single sample-width pulse when the conditions are met. If you need a longer pulse, then use a second trigger, such as the Combi Trigger, to create a longer duration pulse.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(2,534 Views)
I have to do test with those triggers.
br Mika
(2,492 Views)
