DASYLab
Commands multiplexing
Hello there,
I have a weird RS232 device that sends back a lot of different values.
I have to send a specific command to get each value (like "AS001k" for the first one "AS002l" for the second...).
I manage to use global string variables and a slope generator to send one by one each command. (see attached sheet). I don't need to be fast.
But I didn't see how to split each result into different variables. I have one RS232 master input device, and I'm looking for a way to "send" the result to a specific variable/display (e,g if my command counter is 1, send the result to the variable 1, counter =2, send result to variable 2...).
I've searched for a de-multiplexing module, but I didn't manage to find a solution.
Is there a simple way to achieve that ?
Thanks in advance !
Message 1 of 9
(7,533 Views)
The Signal Router module (Control Group) might be able to handle it.
With a control input, you can specify which output to use, and then use a Write Variable to store it for use elsewhere.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
Message 2 of 9
(7,511 Views)
It looks like that this module may solve my problem, but the result is strange... Attached is my worksheet.
On the X input I have the ramp generator (a continuous move from 0 to 6)
On the 0 input I have the incoming serial data.
I use the "edge controlled increment", but when running it does write on the first text block, then multiple times on the second one...
(I had to add a "signal adaptation module" between my ramp generator and the mux module to solve a timing problem.)
I am doing something wrong ?
Thanks !
Message 3 of 9
(7,485 Views)
You don't want edge controlled... you want the input channel on the X input to specify the output channel to use. Note that I also changed the worksheet, to avoid using the alignment module to upsample the data to 11kHz.
Try the attached.
Message 4 of 9
(7,467 Views)
Many thanks !
Let me try to fully understand...
The "edge" mode will increase/decrease the channel output each time that the input detect a rising edge, so I need to provide a clock or rectangle signal
The "Control channel" actually select the output regarding the current input value ? (If my input is >=1 and <2 it will be channel 1)
Is this correct ?
Message 5 of 9
(7,464 Views)
Yes. Your timer was outputting a triangle wave, so there is only one "edge" detected for each cycle.
If you want to use this triangle technique, then the value = channel is the correct setting.
If you use a TTL Pulse Generator to set up a timing signal, then you would use the Edge increment setting. Each rising edge of the timer would change channels. But, then you would need a counter to keep track of where you were in the count.
The complication of the setup is that the input value will repeat one or more times for each channel, depending on the timing/sample rate.
what does the input stream look like? Can't you do the 18 channels individually? Send the data request command for each channel, interpret it, and then send the next one?
Message 6 of 9
(7,458 Views)
Many thanks !
"what does the input stream look like?"
I have a command for each channel :
Channel 1 : $0A05035D\r
Channel 2 : $0A05045E\r
Channel 16 : $0A050E6F\r
So my issue was to send the result of each command in different channels. It works like this, but as you have noticed, I can have issues. (and the speed is limited....)
"Can't you do the 18 channels individually? Send the data request command for each channel, interpret it, and then send the next one?"
Message 7 of 9
(7,452 Views)
Accepted by Yoruk
See the attached. I set up 18 channels, but you didn't have all of the data request commands defined in your worksheet.
Message 8 of 9
(7,448 Views)
MANY thanks for taking time to study my request. This sample looks just perfect !!
So here the system actually sends the first channel command, waits and interpret the answer, then ask the second one ?
Message 9 of 9
(7,446 Views)
