DASYLab
Chart Recorder reading problem.
i've made a data recorder with Dasylab 10 for a vacuum gauge from Adixen (see attachment)
As an analog input  PCI-6023E cart=> formula => Chart recorder
It's working ok on the x-as the timeline is 1 hour, but there is something wrong with the y-as.
It gives for example 0,11E-3 this value is ok but I prefer reading 1,1E-4
I know its the same, but not what we want.
Anybody knows a solution for this?
(9,677 Views)
What about using the Engineering format rather than Exponential format?  You will have the number format as E-3, E-6, E-9 etc..
I like to use this way better becuase, as an engineer, it relate better to m, mm etc...
Other than that, I don't think you can choose how to display the exponential format.
Tom
 InSyS Corp.
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(9,674 Views)
Thanks for the fast reply TomRizzo.
 I tried the exponential format and the enginerings format too. In engineerings format it gives me values like 666.67E6 in the y-scaling.
My line is also not giving the right results. I connected also a list to the output of the formula, there I cant choose the output format.
Do I need a extra module between the formula and the Chartrecorder / List to scale this?
Sorry but this is my first experience with Dasylab, I dont know what is possible or not, I tried this for weeks now to get normal scaling on the y-axis
(9,667 Views)
