Counter/Timer
zero/null/no delay pulse generation on PCI 6602?
1. Error message for triggered task:
For whatever reason, counter input tasks can't use a regular DAQmx Start Trigger.  Instead, you need to set up an "Arm Start Trigger", which is accessible only through the use of a DAQmx Trigger property node.  I'm guessing that's the error you're running into.  If not that, please post code.
2. Sync between tasks:
In what I described, there is hardware sync for t=0 based on the Arm Start Trigger.  From there, you would post-process the buffers of time intervals to extract portions that represent the same time period.  So there's also the need for "software sync" when post-processing the data.
3. Pad Sync and Duplicate Count Prevention:
Haven't heard about the "pad sync" feature in years and not sure I ever used it.  Based on my vague recollection, I doubt you need to concern yourself with it for this app.  As to Duplicate Count Prevention, I suspect you won't need to worry there either.  It's meant for cases where you might get consecutive edges-to-measure with no timebase edges in between.  With your 80 MHz timebase, this shouldn't arise.
-Kevin P
Message 11 of 13
(1,221 Views)
1. OK, I'll test and post results.
2. Exactly! =]
3. OK, thinking again, this is really not a concern is this application (the timing windows must be the closest possible, but never will be in synch).
Thanks again! =D
Message 12 of 13
(1,219 Views)
Kevin_Price escreveu:
Yeah, it worked! =]
Message 13 of 13
(1,201 Views)
