05-26-2008 02:29 PM
05-27-2008 03:42 PM
bernie,
It sounds like you would like to use the counter's gate as the trigger for digital pulse generation. I would suggest looking at the example "Gen Dig Pulse-Retriggerable.vi" in the LabVIEW example finder. The example finder can be located at Help>>Find Examples in LabVIEW. The trigger source would need to be the gate of the counter but please keep in mind that counter 0 gate is PFI9 and counter 1 gate is PFI4. Also, the trigger source needs to be a RTSI, PFI or PXI line to function correctly. For example, if you are using counter 1 and would like to trigger a digital pulse when the counter 1 gate is high then select PFI4 as the trigger source on the front panel.
