キャンセル
次の結果を表示
次の代わりに検索
もしかして:
problem with Counter
hi
A signal gives a correct value, if the speed is under 20km/h. above, somethime not correct. is there a opportunity to don`t show the incorrect value? I mean only the max. value in time?
0 件の賞賛
メッセージ1/4
6,183件の閲覧回数
1. What is the hardware you use?
2. Attached VI.
0 件の賞賛
メッセージ2/4
6,167件の閲覧回数
Hardware a microcontroller Arduino UNO (ATmega328) with LIFA. The Sensor is a reedcontact. Baudrate to Arduino is 115200 Symbol/second.
0 件の賞賛
メッセージ3/4
6,165件の閲覧回数
Can you show us the actual measured graph? It might be due to the fast reading of the device, I would also recommend using some timing functions, as wait or wait until next.
Did you have a look at the examples? Are these working correctly?
0 件の賞賛
メッセージ4/4
6,148件の閲覧回数
