03-27-2008 08:35 PM
03-28-2008 10:06 AM
Looks like for both the digital I/O and timing I/O:
Inputs: 25K-500Kohm
Outputs: 75Kohm
From the 66xx family specifications:
http://www.ni.com/pdf/manuals/372141a.pdf
03-28-2008 10:53 AM
03-28-2008 11:37 AM
Stu:
Good catch, I didn't think too much about it at the time, I needed coffee
I looked at a spec sheet I had on file, dated Feb '04 (P/N 370990A-01) and it shows 75 ohms (56 + 19). I would think 75 ohms is correct, since it is a high speed card.
I have noted quite a bit of typos in NI's spec sheets and manual in the past.
Hopefully someone from NI will see this post and give the definitive answer.
-AK2DM
03-28-2008 02:18 PM - edited 03-28-2008 02:23 PM
03-28-2008 04:37 PM
03-28-2008 04:55 PM
You could use a TTL to 50 ohm line driver (ie 74S140), it will invert your signal though. Could use an inverter (ie 74S04)ahead of the 74S140 to correct for this.
Are you plannin on using 50 ohm coax cable to connect from the 6602 outputs to inputs of your equipment?
03-28-2008 05:06 PM
03-28-2008 05:54 PM
03-28-2008 08:08 PM
