‎06-07-2006 05:27 AM
‎06-08-2006 10:40 AM
‎06-08-2006
03:55 PM
- last edited on
‎02-11-2025
02:04 PM
by
Content Cleaner
Quick correction here, the PCI-6624 is an actual NI board; here is the product sheet for the device.
Now in regard to you question, the board has 8 different counters, so each counter can do its own pulse generation. So having 4 different pulse trains (even with different number of pulses) shouldn't be a problem for this board.
Hope that helps, good luck!
-GDE
‎06-08-2006
03:58 PM
- last edited on
‎04-07-2026
06:03 AM
by
Content Cleaner
Hello T.Q.,
Unless you need non-TTL voltages for your pulse train, I would actually recommend the PCI-6602. You can output pulse trains of higher frequency (up to 80 MHz), and don't have to supply an external voltage source. One thing to realize is that, unlike a continuous pulse train generation task, a finite pulse train task actually requires two counter channels - one to output the pulse, and the other to count the pulses in order to determine when to stop the generation. The PCI-6602 has 8 counters onboard, which is just enough to output 4 finite pulse trains.
I hope this helps,
Travis G.
Applications Engineering
www.ni.com/support
